Emboss feature breaks on 2 out of the 264 profiles
maartenpennings
maartenpennings
I made a template (rectangle) of 264 small rectangles (see emboss0.png).  A subset of those will be "extruded" to form a maze. I wanted to wrap that maze around a cylinder, so I use the Emboss function (emboss1.png). I can add all profiles to emboss, except two. If I add those, I get an error (emboss2.png) and OK is grayed out.
This is my project url according to fusion https://a360.co/3ib1Dr1 but if I click it it doesn't open 😞
This is the URL I get from screencast https://autode.sk/33wELhU but if I click it, it also doesn't open 😞
jhackney1972
I have no explanation for the inability to select the two squares in the profile, maybe there is a limit of some type that you reached.  My solution would just do another Emboss operation using those two squares with the same settings.  Model is attached.
John Hackney, Retired
maartenpennings
Hi John, thanks for your quick reply. I already came up with the workaround you suggested myself. That does work.
As you can see from my recording it is not simply a limit: I can select other squares. So I believe this is a bug. But I don't know how to report those.
jhackney1972
@maartenpennings posted this Emboss issue and he wanted to be sure that the support staff saw it.  I suggested that he send tag you to be sure you, @jeff_strater,  were in the loop, if you are not there already.  Thanks.
jeff_strater
this is clearly a bug, thanks for reporting it, and thanks for the mention, @jhackney1972 - I created FUS-70336 to track this one.  Very strange...  All the profiles around these are fine.  No idea why this fails
Jeff Strater
Engineering Director
patilsm
This week Fusion 360 had a major update to build 2.0.8950. This issue should be fixed in this latest update. Please update Fusion to receive the fix.
Updating Fusion 360:
  • Start or restart Fusion
  • Look at the Job status icon (the small clock in the top bar)
  • If an update is downloading a small 1 appears on the clock.
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
