Fusion Support
Eksportuje mi tylko jeden plik do STL - It only exports one file to STL
3 REPLIES 3
b_wdowiak02
99 Views, 3 Replies
Eksportuje mi tylko jeden plik do STL i tylko chwilę po włączeniu programu, gdy program działa dłużej, bądź chcę eksportować drugi plik staje się to niemożliwe, zacina się na pasku ładowania pliku. Po restarcie programu znów mogę eksportować jeden plik i drugi zacina się na pasku ładowania. Nie wiem czemu tak jest, wcześniej nigdy tak nie miałem i nie zmieniałem w tym czasie ustawień. Pozdrawiam
[translated with Google]
It only exports one file to STL and only a moment after turning on the program, when the program runs longer or I want to export a second file, it becomes impossible, it gets stuck in the file loading bar. After restarting the program, I can export one file again and the other one gets stuck in the loading bar. I don't know why this is, I've never had this happen before and I didn't change the settings at the time. Regards
3 REPLIES 3
jhackney1972
in reply to: b_wdowiak02
You will be much better off using the Save as Mesh command.  Select your body, component or top level assembly, right click your mouse and select the Save as Mesh command.  You will have a lot more options for saving as well.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
b_wdowiak02
in reply to: jhackney1972
I'm printing on a 3D printer and I need stl
g-andresen
Save as mesh offers both STL and 3mf
günther
