Announcements
Edit Number of Side in Sketched Polygon
jhackney1972
Consultant Consultant
jhackney1972
While creating a model sketch, I need a Polygon of 5 sides.  I used an Inscribed Polygon but forgot to change the default number of sides.  I went to edit it, found the polygon icon and selected it but from that point on I cannot find a way to get the number of sides to show up to edit.  I right clicked, double left clicked but I could not find a way to edit the number of sides.  I have tried Circumscribed Polygon as well with the same problem.  Can someone verify this or tell me what my issue is.
John Hackney, Retired
jeff_strater
Yes, this is true.  It is true of most Sketch creation commands - there are no "features" in a sketch, just commands that automate creation of geometry.  That means that editing is limited.  For instance, you cannot edit a sketch fillet, say, and choose a different set of curves to fillet.  Once geometry is created, the only "edit" capability you have is to edit dimensions, delete/create constraints, etc.  The only real exception to this is sketch pattern - you can edit a sketch pattern.
Jeff Strater
Engineering Director
jhackney1972
Thanks Jeff, I saw the Polygon icon in the sketch, and I automatically assumed it would behave like a sketch pattern icon.  Wishful thinking of my part.
