Edit Joint crashes Fusion
When I attempt to edit a joint Fusion crashes. In the screen cast below I select a Planar joint to edit. When the Edit Joint dialog box opens two things are immediately wrong. The joint is shown as a Rigid Joint and the another box opens that says "A joint already exists between the selected components. Do you want to continue?" If I say no, Fusion crashes. If I select Yes the window appears around six times then Fusion crashes. This has been going on for days now.
