Message 1 of 12
Edit a joint found by "Select Referencing Joints"
Once you have isolated the joints associated with a component using "Select Referencing Joints" how do you select the particular joint you want to edit. The obvious solution to right click the joint you want but it doesn't give the "edit joint" option in the list.
I am aware all the joints are highlighted on the timeline but it is a PITA going through them one by one to find the joint you want to edit. As soon as you do one all the highlights disappear and you have to go through the whole loop again to get to the next joint.
