Fusion Support
Edges of solid body created with loft command not fully displayed in drawing.
1 REPLY 1
r.mitschke
85 Views, 1 Reply
Disclaimer: Tangent edges are set to full length, so it has nothing to do with that.
I want to create a drawing that shows an eyelet in front and side view. I created one half of the eyelet using a loft command and then mirrored it. While the front view seems to look ok-ish, the side view does not show the whole form of that body. The problem occurs on solid bodies as well as on surfaces. I found a post from 2017 that describes the same issue. Why is this bug not fixed yet?
1 REPLY 1
@r.mitschke
