Eagle PCB Push Error
I have been successfully been able to push my Eagle PCB design to Fusion until now.   I get an error a minute or two after push that says "Error pushing to Fusion: . "   It only has a period as an error reason.
It does generate a Fusion 360 Translation Report error PDF on the Fusion 360 website portal.
Translation performed for: pcb.pcbxml
Results: No Result.
Input file: pcb.pcbxml,  Output File: pcb.f3d, Result: Error.
Also now when I try to view my project on the Fusion 360 website portal, it gets stuck at Step 1 of 3: Processing Design Data and stalls.
Any suggestions would be appreciate.
Thanks, Bob
*** Solved ***
I deleted the project file on Fusion 360 and re-synced from Eagle as if it were a fresh project.   That fixed it.
dennis.pollmann
I regulary run into the same problem and I also found this workaround. But deleting the PCB and creating a new file is not always a good solution, especially when you use it in a different design. If you delete it you have to redo everything that refers to this part. Has anyone found a real solution for this?
stefan.hofmannDQP64
Community Visitor
Community Visitor
another workaround is to delete all components in eagle and push the empty pcb. Then simply undo the deleting in eagle and push the design again.
But it is also just a wordaround. A real solution would be great.
chase.callenderBS44T
Observer
Observer
To anyone else getting this issue - I managed to work around it by opening the Eagle PCB file in Fusion 360, and pushing it to 3D model from there. None of the above suggestions were working for me
