DXF issues
user71846
Observer Observer
Message 1 of 12
DXF issues
user71846
Observer
Observer
I'm using Fusion in my classroom for 2D design to go to a vinyl cutter. We are exporting as dxf files. This usually works just fine, however sometimes the dxf file has missing lines when brought to the vinyl cutter software (or photopea and other software that opens dxf). Is there a recommended way to use fusion for 2d designs for vinyl cutting?
Replies (11)
Message 2 of 12
g-andresen
try Spline to Polyline Addin
günther
Message 3 of 12
user71846
Observer
Observer
That sounded so promising but sadly it did not help. Even if I open the dxp
in Fusion from the exported dxf, it doesn't come back correctly regardless
of the conversion tolerances I tried.
Message 4 of 12
g-andresen
please share a sample f3d file for reply
günther
Message 5 of 12
bcostley
Observer
Observer
Attached are the f3d and the dxf I got using the add in.
Thanks!
Message 6 of 12
g-andresen
I can confirm the error.
I also noticed in the DXF export from a new file that splines were even ignored and replaced from straight lines.
The error occurs both when importing into ACAD and when re-importing into Fusion.
I think there could @jeff_strater become active.
günther
Message 7 of 12
g-andresen
I rechecked the behavior after restarting the application and found that the error occurs for both the fit point spline and the control point spline only when the endpoints of  splines are connected by a single polyline.
günther
Message 8 of 12
HughesTooling
If you create a 2d drawing from your sample file then save as a DXF it seems to work.
This is what I see in Rhino. File's attached. I used the ANSI drawing template so the DXF is in inches.
Mark Hughes
Owner, Hughes Tooling
Message 9 of 12
g-andresen
It is about saving a sketch as DXF!
günther
Message 10 of 12
HughesTooling
günther
Yes and you've proved it doesn't work so does @user71846 have to wait until it's fixed in a month or 2 or use a workaround? If a workarounds are no longer allowed to be put forward fine I'll delete my suggestion.
Mark Hughes
Message 11 of 12
g-andresen
A small hint that this is a workaround would have avoided all doubts.
günther
Message 12 of 12
user71846
Observer
Observer
Thanks all. I'm planning to simply disallow using splines as they should be
learning to design without them anyway.
