Announcements
DXF Import Fails and hangs Fusion 360
HarrisonClassic
HarrisonClassic
When importing a DXF file into Fusion it just hangs.
Works fine in AutoCAD.
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
  • dxf
HarrisonClassic
Screencast attached
David Harrison
jhackney1972
This is a pretty nasty DXF, you just have to be a little more patient.  By the way, it reports when opening, that there are no declared units in the DXF.  Model is attached.
John Hackney, Retired
TheCADWhisperer
No Screencast???
HarrisonClassic
John, Hi
I was just coming back to edit the post. It finally came in, just took about 30 minutes to do the import.
It's a multi layered DXF, so I might bring it into AutoCAD and "strip" it down to the bare essentials and try that.
Still - a bit too long for an import 🙂
David
David Harrison
HarrisonClassic
I did attempt to upload a screencast, but for some reason it didn't appear in the dropdown. I did paste in the Screencast UTL, hit preview, then Import, but it just said "invalid HTML" and didn't accept the insert for some reason...
David Harrison
