DXF import and export problems
All of a sudden, Fusion 360 has stopped working correctly with DXF files. I've been waiting for some updates hoping it was an error that appeared and would be fixed back but it does not seem to be the case.
First thing I noticed is that I lost funcionality to import DXF files (via "Insert" function). I've been inserting DXF files exported from Adobe Illustrator since ever but from since one or two months back it stopped working. Fusion says "Error: Fails to insert this DXF file!". Of course I've tried every single possible export configurations on Illustrator but nothing seems to help. As stated before, I've been doing this since ever, with several different export configurations and never had any problems.
Second thing is that some partners started complaining they cannot open the DXFs that I've sent them. I usually export metal sheet flat patterns for laser cut. Again, I've been using the same workflow since ever but all of sudden things have gone wrong. Unforunately there is no other option than DXF to use as an alternative so I'm basically stuck.
Third... with so many different evidences that things may not be working well, I've tried exporting and importing back DXFs from Fusion 360, back to Fusion 360, to discover that not even my Fusion 360 client can import back the files it exported. I've tried to export both from a flat pattern and from sketches but nothing worked out.
I can open the DXFs exported from Fusion 360 into Illustrator.
I've uninstalled and reinstalled Fusion 360 but the problem persists.
Thanks!
