Announcements
DXF Files
wmhazzard
DXF Files
wmhazzard
Recently I have been unable to insert or open DXF files, neither ones that I have created nor ones from others. Uploading to the the data panel works but not insert. Is there an issue with this?
karina.harper
Autodesk Support
Autodesk Support
Hi @wmhazzard
Can you share a copy of the DXF you're trying to insert? Have you tried the suggestions in this article (if this is the same error)?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Yes, the error is the one from the article. Nothing worked until I got to the bottom and turned off custom units in document settings. Is this a bug that is being worked on?
karina.harper
Autodesk Support
Autodesk Support
@wmhazzard
Ah - yes that issue is being worked on right now. We should have a fix relatively soon. FUS-194815
Cheers,
Karina
Karina Harper
