dxf export
Hello everyone.
I have problems exporting dxf from fusion 360.
When exporting via the menu the dxf-file will be with wrong measurements (something related to inch) when I open it in edrawings (see attached screenshots).
Someone posted the solution to set units to inch and export a dxf by right click on a sketch. This works well. The units are in mm and measurements correctly when I import the file in edrawings. But then I have polylines instead of circles / splines.
I would prefer the right-click on sketch to export dxf in my workflow. So would be nice if there was a possibility to avoid polylines.
If not, I am also happy if someone has a solution for the inch/mm-problem.
Many thanks
Peter
