- Mute
- Permalink
- Report
I've attached a zip file with a .png file showing what the image looks like (very simple), as well as the original .afdesign and the dxf it exported.
I try to insert into a fresh Fusion workspace using Insert > Insert DXF, then selecting the plane to insert on and the .dxf file from my computer. This is the workflow I've used coming from Adobe Illustrator and had no problems with. However, with the Affinity Designer-generated .dxf, it hangs for a minute, then acts like I didn't select an image and greys out the "OK" button.
1. Is there a way to see the errors that Fusion is throwing (that aren't coming up in the UI in an obvious way)? Something like running Fusion from terminal (I'm on a mac) and seeing tracebacks? I understand this is likely actually an issue with how Affinity Designer exports its .dxf files, but I'm struggling to figure out what that difference is. I'd love to be able to provide some technical data to the Affinity team to see if they can fix the issue.
2. DXF is the only (up to now) reliable format I've had to bring designs from Illustrator to Fusion maintaining consistent scale between the two applications. As I'm leaving Illustrator behind, has anyone else had luck using Affinity (or another Illustrator alternative) to bring vector images into Fusion (in case DXF is the wrong path here)?
