I have an AutoCad drawing that loads in Fusion 360 v2.0.5811 with the wrong scale (10x) . I checked the original file using Autodesk Online and the scale/dimensions are correct. I've seen this issued reported since 2014 for various files formats. I'm surprised to encounter it with an ACad drawing. My drawing is mm, my Fusion 360 default is set to mm, I'm still getting a scale issue 😞
I tried scaling the drawing but it used the fusion 360 origin part center, and not my set origin bottom left corner. so now my small part is way off in space. Is there an anchor feature to go along with the scale function?
