Hi, I am currently having some problems viewing DWG files.
When drawing in AutoCAD, there are colored lines and some dotted lines, and text measurements that I need to be visible in fusion 360 to be able to read the drawing correctly and to be able to start with the cam work. is there some way to make this happen? are there any other types of files that would be better? or are there any specific changes in export from AutoCAD we can try? this is AutoCAD 2009 btw. but the latest fusion 360
also, when I opened the dwg in fusion, it was 10x larger... yes, everything is in mm
