Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Drivers Compatibility
0 REPLIES 0
Message 1 of 1
franhs
153 Views, 0 Replies
Hi! I believe mi AMD RADEON RX6600 is not compatible with the software, I run some tests installing and uninstalling different version of the drivers and found uneven results. How can I solve this issue? thank you!
the main problem is I can not see what I'm doing in te program regarding which commanders I use, it's freezed in the main screen
Labels (1)
0 REPLIES 0
