Dear technical support, I encountered a problem after the latest update of Fusion 360 (2.0.9009)
When I post-process the drill file, Mach 3 crashes for this reason: "Cannot do g1 with zero feed rate".
Analyzing two different drill files (before and after the update of Fusion), it can be seen that the line "G1 F0" is introduced which causes the problem.
Example of Drill file BEFORE Fusion update:
(T2 D=4. CR=0. TAPER=118DEG - ZMIN=-7.202 - FORATURA)
G90 G94 G91.1 G40 G49 G17
G21
G28 G91 Z0.
G90
(FORATURA1)
M5
T2 M6
(PUNTATRAPANO4MM)
S18000 M3
G54
G0 X29. Y105.
G43 Z15. H2
Z5.
G98 G83 X29. Y105. Z-7.202 R5. Q1. F1000.
Y38.
X126.
Y105.
G80
Z15.
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
Example of Drill file AFTER Fusion update:
G21
(WHEN USING FUSION 360 FOR PERSONAL USE, THE FEEDRATE OF RAPID MOVES IS REDUCED TO MATCH THE FEEDRATE OF CUTTING MOVES, WHICH CAN INCREASE MACHINING TIME. UNRESTRICTED RAPID MOVES ARE AVAILABLE WITH A FUSION 360 SUBSCRIPTION.)
G28 G91 Z0.
G90
(FORATURA1)
M5
T2 M6
(PUNTATRAPANO4MM)
S18000 M3
G54
G0 A0.
G0 X215.561 Y76.
G43 Z15. H2
G1 F0.
G0 Z5.
G98 G83 X215.561 Y76. Z-7.202 R5. Q1. F1000.
X158.561 Y82.
Y15.
X61.561
X17.877 Y53.11
X61.561 Y82.
G80
G1 Z15. F0.
G28 G91 Z0.
G90
G28 G91 X0. Y0.
G90
M30
How can this problem be solved?
Thank you,
Rocco
