Dremel 3D Printing Post library not working for 3D45
kalen_gans
kalen_gans
Community Visitor
Community Visitor
I am working with the MFR tool in Fusion 360 and trying to set it to export g-code that can be printed on my Dremel 360 but I have not had any luck. The code generates well and uploads into the printer's online cloud (I can view the print path and everything) but when I go to print, the printer does not extrude any material onto the print bead (it follows the print path as if it was printing but does not extrude.  I have printed other items as a test and they worked just fine, it appears to be something about this G-code.
serge.quiblier
Hi @kalen_gans ,
can i suggest you a test that may fix your problem?
Try posting a new code, desactivating the relative extrusion mode, and test it.
If that solve the issue, please give us a feedback.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
rhyder
@serge.quiblier This option change worked for me to be able to successfully print to the 3D45 from Fusion MFG! Thanks for the suggestion and happy printing!
