& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hey
The drawing environment used to be hassle-free, however since the last update all my drawings have turned out to look just like the one beneath. When exported (Print to PDF) the drawing looks just fine, but of course this bug is impossible to work with in spite of that.
Sincerely Daniel
Did you restart Fusion 360 after you updated it? If you would, please attach the MODEL of the 2D Drawing you are showing the issue. I would like to create it and see if I get the same issue. I suspect your need to either update your graphic drivers or switch to a different Graphics Driver in your Fusion 360 Preferences.
John Hackney, Retired
This is a graphics driver setup issue. Some AMD drivers have been affected by Windows updates.
Please install the latest driver for your graphics card manufacturer. You can get to the right site by following the steps below, then entering your graphics card details.
Thank you!
Updating the graphics driver solved the issue!
Best regards
Daniel
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
