@TheCADWhisperer wrote:
I would make correct modeling decisions for 3D printing (and for machining).
I am not convinced that you recognize the issue.
Thats a very passive aggressive, and completely unhelpful reply. I stated the reasons I made the design decisions (intial design was for 3D printing, not machining), and those modifications did help reach the goal I was hoping to achieve. Furthermore, why bother even commenting if you don't plan to help. Saying that someone doesn't recognize the issue, without pointing the issue out, is completely useless, and comes off as snobbish. How do you expect someone to fix something you perceive as an issue without telling them what the your problem with it is?
Plus, the issue pointed out has nothing to do with the freezing issue anyway, which is what I was pointing out. I didn't need model help, I was bringing light to an issue that may exist in the drawing tool.
All that said, I restarted the drawing from scratch for a third time, since the first two crashes resulted in autodesk having corrupt files and being 'unable to download file' in F360. I was able to create the drawing I needed.
EDIT: After this reply posted, I was able to see your edit, where you pasted a second screenshot after the one calling out a supposed mistake of mine. Unsure why that didn't load prior to making the reply. It appears you made threads come out the top of the chamfer to assist with lead-in. Interesting thought, but still unhelpful, IMO. I've never seen a machine shop do anything like the 'thread lead-in' on the right side of the 2nd of the image you posted. And unless you have a very large thread (which M3 is not), it won't really help with the 3D printing, since it would most likely just put some material in the way of the hole that would be counterproductive to a leadin. I stand by my design decision, as my testing has proven it is works well enough.
Plus, as I said, I wouldn't have needed the lead-in in F360 was still loading in custom threads properly. I didn't need a lead-in when that was working.
