Drawing template elements only show on the first sheet
I set up a template with several elements outside of the Title Block.
I set up a Custom Table on a drawing template Component sheet. It's supposed to be for me to enter the next assembly that part/assembly is used on, and what sheet that is. Similar story with a revision table on the cover page.
I put in an image as well (in this case to white-out a section of the title block without creating a second block, so I can edit the whole drawing set block at once. But that shouldn't matter)
Problem is, when I create a drawing of an assembly from that template, only the first sheet with a given element has that element!
The first assembly sheet has the white-out rectangle and revision table, the first component sheet has a Next Assembly table, etc.
But every subsequent assembly or component sheet is missing those elements.
The only elements that are preserved are model views of all types, parts lists, bend tables and title blocks.
So basically half of the elements you can supposedly add to a drawing template are broken. What's up with that?
