Hi All,
I'm experiencing an issue when I want to create a drawing from an existing template I've created. When I open the template from the drawing from design tab information on the template is missing. See details in images below.
I select the template I want to use (see image below).
But when the drawing opens its missing information in the template.
See image below that has missing information in red boxes which I've added to the image for depicting locations.
The information that should be contained in the red box is in the image below.
The interesting part is that all the information displays when the I directly open the file without associating it to a design.
Any ideas how to fix this?
-Austin R.
