Fusion Support
Drawing Space Breaks Mouse
3 REPLIES 3
bensporn
185 Views, 3 Replies
Since the update, if I enter a drawing workspace my mouse stops functioning as it should.  I can still move the pointer around, but the pointer is a cross-hair type pointer as if I were lasso selecting objects.  I also cannot click on anything within fusion and have to force restart the program to get it to work again.  If I open another drawing workspace, the issue happens again.
Any ideas?
3 REPLIES 3
bensporn
in reply to: bensporn
Fully uninstalling and re-installing seemed to fix it
zachSKK2Q
I and my coworker are both having this issue.  I've reinstalled with no effect.  Then I did a clean install with no effect.
rekelis.designs
Reinstalling doesn't fix it.. I tried it.. it came back after a while..
If you Toggle selection Filters > Select Through it seems to work for a mouse operation but reverts back.. is this the same thing happening to you?
https://forums.autodesk.com/t5/fusion-360-support/mouse-bug-after-recent-update/td-p/12051907
