please show this behaviour in a screencast
günther
It happens after every 15th renumbering.
After that I need to restart the fusion 360. Nothing works.
Drawing - renumber
Hi @Anonymous
Please send me your dataset (instructions here). If the data is sensitive, you can send it to me directly Clint. Brown {a} autodesk.com
Also please send your diagnostic files over as well.
In Attachment.
I hope I sent everything
Thank you. We'll take a look
Hi @Anonymous
Our Dev team has had a look at this and are not able to reproduce the hanging that you are reporting.
Would it be possible to record a screencast of the steps taken that cause the issue? This would be most helpful.
One other thing that you could try, is to clear your cache.
I'll clear the cache.
Hi @Anonymous
Thank you for sharing the screenshots.
Did clearing the cache make any difference? Are you still experiencing this problem every 10-15 renumbers?
Did clearing the cache make any difference? - Unfortunately not.
Maybe I click renumber too quickly after the save, because it's still saving ? i dont know
