Fusion Support
Drawing Issue
6 REPLIES 6
556 Views, 6 Replies
Drawing Issue
Hi there
Every time I create a new view in a drawing and attempt to suppress components from that particular view it beachballs eventually recovers and takes an unusable amount of time to catch up. Why is this happening?
6 REPLIES 6
innovatenate
It sounds like Fusion may be redrawing the placed views in the drawing. Is the component that you're toggling the visibility for a complex one? Can you share the Fusion design?
Nathan Chandler
Principal Specialist
in reply to: innovatenate
link: http://a360.co/2fXX9cp
password: logan
thanks!
innovatenate
It looks like the views take a long time to redraw because of the modeled threads. The modeled threads are computationally expensive to project into a drawing view. If you suppress the threads, you'll see the performance increase for redrawing views. Try this link out as an example.
http://a360.co/2vSXYca
Password: lessthreads
I hope this helps.
Nathan Chandler
I think I can see what you mean in your drawing however how do you suppress
the threads?
Maowen_Zhang
@Anonymous, as below image, you could change thread feature to turn off 'Modeled' option if it's not required for you. It could help 2d drawing generate drawing views faster.
Lori Zhang (Fusion Development)
