You didn't frustrate me, Autodesk did it with this way to do that is systematic.
All times I contact the support they ask me to access files, projects and all things. All times they bring me away with some standard check, all times seems they ae not capable to reproduce the problem, as all is new for them. I spent hour trying to help Autodesk to be aware about problems that they seems to don't know until I discover from the forum that is a common and diffuse issue and they're clearly aware about it.
All times it seems that is something related to me, to my hardware, to my OS installation and only to me while is clear that something went wrong and they're trying to solve the problem letting as little people know that there's a bug until they release a new version solving it (at least some time) and publishing it like a victory in the new release announcement.
This is not a problem that you are not capable to communicate with me or to reproduce the issue, is clearly a policy of the company, a way to operate and I am really tired about it and angry with myself that I put myself in this rabbit hole again.
I tried to wait until this little and big glitches solves by next release like usual, but nobody seems to take care about any of the many problem that I previously bring to the forum some months ago and instead Autodesk continue to release new functionality that usually does not work well, make the software more complex and bring many related bugs in the rest of the software.
I don't say that I do not like Fusion and I cannot use it productively also with this bugs, but please.... please... change this way to interface with the costumers, because this is making things worse.
If, as I imagine, at Autodesk you know what is the problem (software bugs, database, combination of both...) simply say that you're working to solve the glitches that many users are encountering and do not say that for use Fusion we need to have a quadro (and probably will not works anyway).
Sorry if I make so many and big assumption about things that I cannot know, but I think I can recognize a pattern when I see one and repeated for so many times.
I do not want to lost my and your time in a call... anyway you cannot solve all this problems by yourself and it will make me only more angry. Things will solve with next releases as usual or I will simply change software with something that simply works or at least have a better support.
