Drawing - dimension decimal separator doesn't switch to comma
1anton1korobov
1anton1korobov
Hello everyone!
I faced an issue.
Setting: "Units and Value Display -> Decimal point display" doesn't switch to comma. Fusion always displays dot. (14.97 instead 14,97)
Thanks in advance!
Replies (8)
Phil.E
Thanks for posting. I tried this in a windows machine, and can successfully change the preference for Decimal Point display.
  • Are you on mac?
  • Can you please check the build number (on the Help>About box)?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
1anton1korobov
Edition: Windows 11 Pro.
Version: 23H2
Os build: 22631.3296
Thanks for answering
Phil.E
Thanks for the info.
Can you please verify which Fusion build you are using? The build number is found on the About box, which is found on the Help menu, upper right corner of the application window.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
1anton1korobov
Fusion 2.0.18719 x86_64
Phil.E
Can you please provide a video? I'm stumped how this happens for you, but not in my testing. I want to ensure I'm taking the same exact steps as you are.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
1anton1korobov
Reboot/creatig new drawing doesn't help
Settings:
1anton1korobov
Still have the issue. I have tried running Fusion on a different PC with the same result. Could it be a problem based on account settings or region? Current region - Poland. System language - English.
Specs of new PC:
Edition Windows 11 Pro
Version 23H2
Installed on ‎14/‎06/‎2024
OS build 22631.3737
Experience Windows Feature Experience Pack 1000.22700.1009.0
Also attaching windows Format settings. They are default
ClintBrown3D
Hi @1anton1korobov
This is currently not possible. But there’s good news. The team is busy working on a feature that will allow you to set your delimiter to a comma.
This is currently planned for the September release (but as with all software development projects, this is subject to testing validation, so could be delayed if there are any issues).
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
