Drawing cannot be saved.
I have this po-up message when I am trying to save my drawing file:
"Derive references can only be created within the same hub and within the same project. Please Select a Design that meets these criteria."
My drawing are created from my myin design.
Louis
jeff_strater
@Anonymous - what this error message is telling you is that you are trying to save a design into a project that is different from the project where the source of a Derive feature exists.  All inter-design relationships (external referenced components, drawings, and Derive) must exist in the same project.
Jeff Strater
Engineering Director
Hi Jeff,
Thank you, it seems fine now.
Best regards,
Louis
cedavis
Community Visitor
Community Visitor
This is not helping me out. In the same project, I can in 30 seconds make a drawing from animation. Quickly save it to make sure it is "savable", no change to project or location, and I get this error:
"Derive references can only be created within the same Hub and within the same Project. Please select a Design that meets these criteria."
I appreciate some help, please.
cedavis
Community Visitor
Community Visitor
Plus, it doesn't let me chose anywhere else anyway. The only thing I can chose is a new filename - nothing else. It's a dialog box to nowhere it seems.
bruce_vandev
Community Visitor
Community Visitor
Not helpful as there is nothing in the properties window that identifies the location of the derive (derived) references. You should always be able to identify the references.
