I finished a drawing last night referencing an assembly called compressor backpack, a subassembly within that is called Daikin Inverter but the base view for the drawing has always referenced the top level assembly. When I opened it this morning the default page opened to where I finished last night but I noticed that the base view had changed to the inverter (picture 1). after clicking through the pages of the drawing I confirmed that it had all changed somehow and going back to the default page all of my views had changed (Picture 2). I messed with it a little trying to switch the base view source back but eventually abandoned it and and just loaded the version from before which was still correctly sourcing the compressor backpack and am going to start redoing the work I did last night as v7 (picture 3).
Has anyone else run into this problem and fixed it? These views are what I had saved originally but you can see that the base view source is now reading Daikin inverter
after refreshing the page the views changed to the actual inverter
