drawing always turns black, faces are no longer visible.
Message 1 of 16
If I sketch a square, then extrude it. The result turns black, making it very difficult to do anything else.
Is this normal? Or have I screwed up preferences some way?
Can I reset preferences to factory defaults?
Replies (15)
Message 2 of 16
m.podsiadlowicz
Maybe change material to non-black in preferences ?
Message 3 of 16
Currently material is from Fusion 360 library, metal,  steel
Changing it to white plastic makes no difference at all
Message 4 of 16
g-andresen
check what @m.podsiadlowicz  said.
günther
Sorry, didn’t register your contribution above.
Message 5 of 16
The image looks like what I had. (It's been changed many times with no difference to the drawing, or recreated drawing).
Message 6 of 16
ryan.bales
Autodesk Support
Autodesk Support
I think if its not environmental (settings in fusion) it could be graphics. But i'm leaning toward environment.
What are your effects set to and what is the environment?
Ryan Bales
Fusion 360 Product Support
Message 7 of 16
See attached screen cast for settings. I'm running on Windows 10 Virtualbox on Linux desktop. (god I wish you guys would allow for installation on Linux, I would have been a customer for years now).
The virtualbox doesn't have any problems with other graphics, but is nothing special. 3d and 2d acceleration is enabled. Resolution is 1920x1080.
Message 8 of 16
ryan.bales
Autodesk Support
Autodesk Support
It's 'possible' that is the cause but i'm not seeing any screencast or screenshots showing your settings.
Ryan Bales
Message 9 of 16
Sorry bout that. Thought it was attached.
Message 10 of 16
ryan.bales
Autodesk Support
Autodesk Support
First test best performance vs display and then I'm looking for is this:
Ryan Bales
Message 11 of 16
I'm not sure what you are referring to with testing best performance vs display. Is this a built in test, or something windowish, or an external test?
I've tried adjusting all those settings, currently effects are:
ground plane
ground shadow
ambient occlusion
environment is :
infinity pool
Changing the environment changes the backdrop but the model remains black.
Message 12 of 16
ryan.bales
Autodesk Support
Autodesk Support
You have settings turned up rather high with all those on. it may be what's causing it to tweak out. Disabling the effects, and using better performance vs display. Test DX9 instead of Auto or DX11 in General settings.
You could try tweaking the active graphics driver as well but i'm not sure this would do it.
Ryan Bales
Message 13 of 16
Tried changing to dx9 and removing all effects, going as simple as possible. No difference.
It really seems to me like it's just putting the wrong colors on. When I mouse over a plane it turns gray. So it can update the colors ok.
Message 14 of 16
ryan.bales
Autodesk Support
Autodesk Support
The test for that would be resetting your materials overrides or assigning different materials. At some point you have to look at graphics drivers and see what its at. This is not a recommended or supported configuration and its not easy to pinpoint.
Ryan Bales
Message 15 of 16
Well, for completeness sake, here are the graphics drivers specs.
Windows Displays the graphics drivers as "VirtualBox Graphics Adapter (WDDM)" and uses memory from 0xa0000 to 0xbffff (131071 bytes)
The VirtualBox has settings of 256MB display memory (not sure why it's different) 200% scale, 2d and 3d hardware acceleration enabled.
Virtualbox is running on a machine that is using an NVIDIA driver 418.23
Perhaps it's the scaling that is causing problems.
Message 16 of 16
It looks like virtualbox doesn't support graphics as well as claimed. Running an opengl test, it all passed, but didn't actually show anything on the screen!
So I'm beginning to suspect the problem is with virtualbox. Thank you for your help.
