Announcements
Drawing a line between 2 offset objects in 3D
ktnalive
ktnalive
I have a 3D object that I had offset from the original, I did this so that I could create 2 walls. Now I need to create a roof and a floor for these two walls. Fusion will not allow me to do so, even when using THIN EXTRUDE. I also wanted to show the distance between the 2 walls, again Fusion will not allow me to do so. how do I fix this?
Attached is a picture of the 2 walls.
 The wall on the left is the original.
TheCADWhisperer
@ktnalive
This should all be very easy.
ktnalive
Here is the file you requested. Thanks for your time.
jhackney1972
Is the attached model something like you are looking for?  By the way, your side panels, in the supplied file, were not aligned, they are now.
John Hackney, Retired
ktnalive
Thanks. Was the alignment the only thing preventing me from creating a ceiling? If not, how did you get the 2 to join?
I apologize for not addressing your question earlier. However, I have followed your suggestion and successfully uploaded the file.
