Announcements
Dpi issue after last update
mbelusa.mail
mbelusa.mail
after yesterday's update there is again a problem with DPI scaling like about a year ago. Icons and texts are big, the environment is unusable for work. My Laptop 14" 1920x1080 DPI 150%. The solution that worked before - discover scalink via Fusion 360 settings in window is now broken again. Please fix ASAP.
Is there possibility to prvious version downgrade?
Thanks Marek.
mbelusa.mail
Temporery fixed with create batch file on desktop:
setlocal
set QT_ENABLE_HIGHDPI_SCALING=0
call %appdata%\..\Local\Autodesk\webdeploy\production\df098dc22bdb0532c3884db0a2d6182c8f8678de\Fusion360.exe
endlocal
(The solution from other user from this forum )
M.
CADacombs
I have the same problem with Fusion 2.0.19207 x86_64 on Windows 10 Pro 22H2 (19045.4291) with 125% scale on 1920 x 1080 resolution.
Instead of using the batch file, I set QT_ENABLE_HIGHDPI_SCALING to 0 in Window's System Properties > Environment Variables... Like it did last year, setting this variable has corrected the display.
Here is that thread from last year: Solved: Re: high DPI scaling completely broken with most recent update - Autodesk Community - Fusion
@lance.carocci
