Fusion Support
Double Projected Geometry on First Try
5 REPLIES 5
sewais
117 Views, 5 Replies
Greetings,
I've noticed this happening multiple times, & can almost replicate it as needed. When ever sketching & selecting the PROJECT feature, then selecting a face, the geometry generated is doubled up on top of itself. This is extremely irritating as deleting or 'breaking links' just doesn't do anything sometimes.
Any one else experiencing the same thing?
5 REPLIES 5
davebYYPCU
in reply to: sewais
You have that behaviour because the face is projected on selection of the face.
It a preference setting.  Start over, after selecting a face to put the sketch on, hide the body, you will have projected the face, but the purple outlines are not showing un5il you mouse over the boundaries.
Either turn off the preference setting, or don’t Project the face manually.
Might help….
sewais
in reply to: sewais
Hi Dave,
Can you give an example? Or show where this preference setting is?
I need to project some geometry from the face & tie it into geometry that I offset.
This only happens on the first extract. Once I delete all the projected geometry, & try again, it works as intended.
davebYYPCU
in reply to: sewais
Preferences, check for Auto project on reference, or similar,
or are you looking for the preferences.
In the movie second time round the sketch exists,
Repeatable for when creating new sketch, on a selected face, until you turn off that Preference.
Might help….
sewais
in reply to: sewais
Dave,
I found it. Thank you for your help.
jhackney1972
in reply to: sewais
I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
John Hackney, Retired
