door handle align
paul.jacobs5
door handle align
paul.jacobs5
hello,
i imported a handle and now i would like to align it in the middle of my cabinet door how do i do this gr Paul
hamid.sh.
Use Joints.
Hamid
jhackney1972
Just a little note to add to @hamid.sh. post.  To use Joints, you must have Components, not bodies.  A lot of imported models are just bodies so you will have to convert them first.  Attach your model and someone on the Forum will be able to direct you better.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
