Doesn't update after changing the position of the refered plan
First I created an axis threw a cylinder. Then a plane that is defined by the axis and an angle. Afterward I created a section view that is set on the plane.
The issue is, that if i change the angle of the plane the section view is still be on the old position and doesn't update.
The only way to fix it is to reference the section view again.
Does anybody has the same issue or is there already a solution? Thanks!
