Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have educational access, but I still have the same limitations in Fusion as in the free (not for commercial use) version.
I can't use simulation; I have the 10 editable files limit and other limitations. Shouldn't I have the full version as a student?
Solved by jhackney1972. Go to Solution.
Yes, have you logged out of Fusion and logged in with your Educational License Autodesk ID? Also, how long has it been since you received your Educational License, it takes a short time to catch up with you. If this does not help, maybe you should contact Educational support on the same page you applied from your license.
John Hackney, Retired
