Announcements
Dissable step by parameter
liviuslivius
liviuslivius
Hi
i use parametric design and i do not see a way to dissable some step by parameter value.
E.g. When some parameter is lower then 2 then i do do not need e.g. extrude, filet... step.
How can i do this by parameter? I see option by right click "suppress" step, but this is manual action, not parametric.
jeff_strater
that is correct.  There is no "conditional compute" in Fusion parameters.  You might be able to do something clever with the floor() or round() functions.  Even then, a zero-distance extrude will cause an error.  What you probably need is configurations, which are currently under development in Fusion.
Jeff Strater
Engineering Director
jhackney1972
Conditional and If-Else-Then statements are not available in base Fusion 360.  You can attempt to write a script or add-in but that is about it.  This Forum post suggest this and an alternative.
John Hackney, Retired
