Announcements
Dims lines move when making any change to design
WoodcraftMark
WoodcraftMark
I've been having an issue since I started using Fusion.  If I put a dimension to a specific point then the design changes (even if that spot doesn't change) the dimension is placed in another point.  We make booths and I have a dimension to the top of the seat to the bottom of the booth and a dimension from the front of the seat to the back.  The top front edge of the seat is a radiused fillet.  So on paper the seat height is to the top of the curve, the depth is to the front of the curve.  When I update, it almost always switches these two points.  Every single time I update a drawing, I have to check if they moved and adjust them.  It's not losing the association, it never asks me to re-associate these.
g-andresen
please show the process in a screeencast
günther
ClintBrown3D
Hi @WoodcraftMark
Please can you share a bit more information, are you having this issue in the sketch environment or in the 2D drawings workspace?
Are you able to share a screenshot or a screencast as @g-andresen has suggested?
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
