Message 1 of 13
01:51 AM
I'm trying to draw a honeycombe inside a circle. Tutorials suggest drawing a cluster of 4 and using a rectangular pattern to distribute evenly. When I go to equalize and narrow the distance between those first 4 hexagons, instead of budging them into position, Fusion just resizes the polygons instead to satisfy the new spacing dimension. I'm guessing this has something to do with constraints and it's driving me bleeping mad too. Furthermore, a lot of the dimensions between two lines are showing up as angular degree dimensions, I'm guessing because I failed to draw perfectly parallel polygons.
