Dimension Over Constrained
et_cetera
et_cetera
Hi!
I'm trying to model a computer mouse. After I finished making a first draft, I realized that the mouse was too tall and too long. But when I tried to change the dimensions, the program says that the sketch is over constrained. Which other dimensions or constraints do I have to change/delete before I can edit the height/length of the mouse in sketches 1 and 2? Much appreciated, thanks 🙂
HughesTooling
You have lines that are green(Fixed), you need to unfix them.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Rather than use Fix you should constrain the construction rectangle to the origin to give more predictable edits.
Screencast demonstrates how to constrain the rectangle.
Mark
Mark Hughes
et_cetera
How do I change the height in sketch 2? It's still over constrained. Thx
et_cetera
It turns out I had another spline that was fixed. Thanks for your help
