Announcements
Dimension Formula with parameter multiplication failing
gliebig
gliebig
I'm using the parameters to make a saleable star to be used in a Christmas display. Pretty simple. StarDiameter=x, MaterialThickness=y. I'm trying to dimension circumscribed circle around the 5 pointed star using the following formula StarDiameter * (1 + MaterialThickness) and Fusion refuses the formula. 1+MaterialThickness works but when I try to multiply it fails. Here are the parameters:
StarDiameter = 42 in
MaterialThickness = .188 (3/16) in
I would have thought this would have been pretty simple. Any ideas?
alessandro.gasso
Hi, the result of the formula StarDiameter * (1 + MaterialThickness) is Square Inches.
If you write the formula like this (StarDiameter * (1 + MaterialThickness))/1 in, you get the result in inch and Fusion will accept it.
I hope it helps.
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
g-andresen
(1 + MaterialThickness) > wrong
instead:
(1 in +MaterialThickness)
Formula:
XX = StarDiameter * (1in+ MaterialThickness) / 1in
günther
gliebig
I just tried that and it does not work. Note: xx is becoming a unitless scaling factor for the circumscribing circle.
MaterialThickness = 3/16 in (.188)
These two formulas work:
xx=(1 + MaterialThickness)
xx=(1in + Material Thickness)/1in
xx = 1.188 with either formula
but when I try to multiply xx by StarDiameter the formula fails.
g-andresen
if you need it unitless > divide Stardiameter by 1in
this way:  XX = Stardiameter / 1 in * ( 1 in + MaterialThickness ) / 1 in
günther
gliebig
This is what finally worked:
( 1 in + MaterialThickness ) * StarDiameter / in
Thank you for pointing out In^2
