Hello all, Im trying to seperate this body into 4 parts, i need those edges to be mitred.
Ive tried a few different methods to accomplish the split body, construction planes and surfaces.
When I tried splitting the body, I received an error stating the tool doesn't intersect the body. Extending the tool cuts parts I do not intend to cut. (you can see the cut in the back where the radius of the extension extended into the back.
This would be fine, i could just join the two parts of the back together to fix that problem, but then that causes issues with the parameters when i change the dimensions of the part later on, i get strange artifacts.
The cutting tool does indeed extend past the body out the front, top and bottom. Is the problem related to the tool not extending out the back of the part?
Im pretty stumped on this one. Im sure there is a better way of doing this that im just not aware of.
In a nutshell: I'm looking for guidance on how to correctly split this hollow prism into its four sides, with miter joints at the corners. Any advice or alternative methods would be greatly appreciated.
