Announcements
Designs inserted from another hub will not be linked
fusion3608TH2K
fusion3608TH2K
I moved a project over from single user to a team hub. Now ironically it won't let me insert components into other assemblies without copying them, even when both designs are in the same folder, in the same project, in the same hub. Is there any way to fix this? Such a message shouldn't even exist the way I understand the team hub, it seems like I can only be in one hub at a time.
abhinav_singh
Hi, please make sure you are in your Fusion Team hub and not your Personal hub (top left hub switcher dropdown).
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/SaC...
Abhinav Singh
Product Owner
fusion3608TH2K
Well like I said, I'm not sure how I could actually move a design from one hub to another unless I reuploaded it. So yes I was in the team hub from the dropdown. However after a restart at fusion update to version 2.0.10244 it seems to be working as a linked file.
