First time I've had this particular issue on Fusion with not being able to save my design. I haven't changed anything in my build process so it is a confusing error to be happening over and over again even after removing components that I inserted into the design. I don't really want to break the link on the inserted components if I don't have to, unsure if that will fix it or not doing that method.
I went through the issue in the screencast so check it out and see if it makes sense
This is the error I'm receiving when I try to save:
Error: [CFS] Save of the cloud file RAM DECK welding deck v1 is aborted because it is referencing a local file Alumareel Air hose reel v0
