Announcements
“Design looks fine. No unresolved components detected.”
sattju
sattju
I am having an issue where I open a model that was done in Inventor, (we are transitioning to Fusion 360) along with all of its components. It opens fine. Before I am able to edit, it will ask me to compute unresolved components. I will click to compute unresolved get the message stating that my design looks fine and have no unresolved components. I begin editing like normal and am able to save without any problem. The problem is when I go to create drawings. I am able to place views and do everything I am needing to do as well as save it, but if I were to close that drawing file and reopen it, I am not able to do so. It will tell me that it has unresolved components and can’t open. So I’ve basically lost all of my work because I literally can’t open the file. Does anyone else have this problem or no how to resolve it?
jhackney1972
I do this process all the time without error or issues.  I think you just happened to get a fluke upload.  Try another small assembly.  Note if you see an PDF files generated in the Data Panel indicating any issues in the upload.  If not, do a quick drawing of a component, just a view, save and then check.
John Hackney, Retired
