Announcements
Design > 2-Point Rectangle > Tab to 2nd dimension won't accept (v2.0.8560/Win 7)
tomas.sooky
Observer
tomas.sooky
Observer
Observer
Fusion 360: v 2.0.8560
OS: Win 7 64-bit (v6.1, SP1)
Hi there,
I'd like to report the following issue:
When creating a 2-point rectangle in Design mode, once you add the first dimension and press tab to switch to the second dimension, the second dimension entered in the number field won't get accepted. After pressing enter, the second dimension remains as originally drawn with the mouse instead of the program automatically modifying the dimension according to the number specified in the number field.
The second dimension can be consequently edited by clicking on the number field, though.
The same issue is not present on Win 10 64-bit (v 10.0.18363 Build 18363).
Any help would be greatly appreciated.
Best regards,
Tomas
TheCADWhisperer
Is Fusion 360 supported on Windows 7?
tomas.sooky
Observer
Observer
Thank you for pointing that out.
This is how it started after the update. Explain this compulsion to switch to Windows 10? how to solve a problem?
etienne.thierry
Community Visitor
Community Visitor
Same problem on win7 pro 64 bits, values entered by keyboard are not used by Fusion, size entered by mouse is used . Any solution ?
g-andresen
1. maybe Compatibility Mode helps > INFO #18
    But: The system can slow down
2. I prefer this way:
günther
