I have a Design that overloads my system and is unworkable. However this file is not very large. I copied a component from a larger file and this design is relatively young with only a few functions in the timeline. I have designs with timelines a mile long and can still open them and perform tasks at a very fast rate. Because of this I'm wondering if performing certain functions on this design are causing the performance issues or if I should be using an alternative method other than Copy>Paste New into a new design. That being said I've also used this technique on the other very large files I've mentioned with no issues. I may be wrong but it seems when I perform a Shell function and or delete faces from a body this starts to happen where performance is compromised. Even drawing a straight line on a text will crash the system or take minutes before the system catches up.
Graphics Diagnostics - https://share.getcloudapp.com/wbu9K24v
