Description of Fusion 360 Icons and guide book.
Jaeger1787
Message 1 of 14
Jaeger1787
Hi Folks.
Fusion 360 has a plethora of icons.  Some are intuitively recogniseable, others less so.
For example, I now believe that this symbol  Icon 1.jpg indicates that a sketch is fully defined, but what does this Icon 2.jpg mean.  I am assuming it indicates the sketch is not complete, but this is a guess.
Can someone point me to a document that lists all the icons, with illustrations and an explanation of what the icon implies or indicates?
Secondly, is there a book recommendation that will take a beginner through Fusion 360, using the new interface.
Keith
Replies (13)
Message 2 of 14
MoshiurRashid
Hi
Thanks for posting. This Icon 2.jpg icon means there is a sketch profile and it is under constrained (not fully constrained or defined). Well, I couldn't find any complete list for all symbols of fusion 360. If you feel confusion about any symbol in future, post it in the forum and tag me. 🙂 I will tell you what those are.
For learning, I suggest you to check the Learn section of the forum. It is great.
Stay healthy
God bless
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 3 of 14
TheCADWhisperer
Message 4 of 14
g-andresen
maybe a start at this point brings some light into darkness.
günther
Message 5 of 14
Jaeger1787
Thanks for the book list.  I have looked at some of them, only to find that the majority are still working on the older User Interface.  As some commands have been moved around, one is then left to search for them simply to follow the  tutorial.  Others give no indication as to their state of play, and I am reluctant to shell out on a book that leaves me just as high and dry.
Thanks also to others for their suggestions re Icons.
Keith
Message 6 of 14
Jaeger1787
Dear Moshiur.
Can you please tell me the significance of this icon:
Assuming it is some form of error indicator, what do I need to do to correct it?
Thanks.
Keith
Message 7 of 14
g-andresen
1. orange > surface
2. white >solid (watertight)
günther
Message 8 of 14
Jaeger1787
Thanks Günther.
I had created it as a reference surface for a sketch.  I was able to
delete it, as no longer required.
Keith
Message 9 of 14
Inspections_JCH
This topic is near and dear to my heart. How would we do a search of the support documentation when we do not yet know what an icon is named? And when we know the name of an icon and want the definition that goes with the name, how would we find it in the 1800 results that are returned to our query? And please, this is not a request for a link to Amazon. I have been there.
Message 10 of 14
Gerrik_Labra
Community Visitor
Community Visitor
Can anyone help me understand the Chain icon for the components, after importing a new component?
Message 11 of 14
jeff_strater
yes.  That badge on the component icon indicates that the component is external (linked).  As opposed to "local" components created with the New Component command.
Jeff Strater
Engineering Director
Message 12 of 14
Gerrik_Labra
Community Visitor
Community Visitor
Thank you so much!
Message 13 of 14
Jaeger1787
OK, Folks.
Line colours
I know that blue indicates an unconstrained line,
black indicates a constrained line.
But, what does a line coloured green
and a yellow line
and one coloured purple indicate?
Message 14 of 14
TheCADWhisperer
Blue - Underconstrained object line
Black - Fully defined object line
Green - Fixed Constraint (fully defined)
Brown - Underconstrained Construction line (also dashed)
Purple - Projected geometry.
Yellow - Lost Reference
Also - Center Lines
White dots - Unconstrained
Black dots - Constrained
Green dots - Fixed
Green (actually all of these colors depend on current Environment setting).
