Announcements
Description field in component properties
New user here.
Should the description field in component properties  autofill with info such as body size or does it have to be manually input? I'm using fusion for woodworking and noticed this went I was using the parts list. I noticed the description field is blank.
tallisb
Hello-
The "Description" field is left blank and is there for you to add in a description if needed.  Such as "purchase from McMaster-Carr" or "3D Printed Gear", etc.
Brad
Brad Tallis
Fusion 360 Technical Specialist
