Hi All,
You can blame this on Jason. On his train parts video, he used insert derive to ensure all the mating parts worked and were built the same. I have taken this and really gone to town on this methodology. The derived parts are just sketches, so no meat on them. However, a couple of things have popped up that range from livable to this needs to be fixed.
The livable is that a derived part can only be derived from once. Ok, just copy and paste new, but the link is broken in the process on copied parts. If you are wanting to have the same feature at odd places, the copies are all not linked. Side note: once plopped into the new model, the derived parts cannot be moved around the browser, so proper planning needs to be done to congregate future copies.
The next bugaboo is that only one profile can be used at a time, so if two profiles from different parts are tried to extrude in the same plane, only one can be, so it causes additional extrusions. OK, so time line is more complicated.
The straw that caused this post is that when I add a sketch to the inserted part, only the original profile is able to be selected, so, if I want to not extrude a portion of the profile, it is an actually not able to be selected. I did work around this by added yet another extrusion feature (YAEF)tm, but this is again extra timeline stuff. I suppose it is related to the bugaboo, but still.
I have include two test files that demonstrate this.
I think that this is at least three feature/bug requests, so, can these be fixed by Tuesday? /s
Many Thanks,
Rob
2.0.13881
Active Plan: Fusion 360, Subscription
macOS 12.5.1 x86_64 (21G83) on MacBookPro18,3
